    Dismiss Notice
zinc-plated steel bolts okay for application: skidplate f650gs?
Discussion in 'The Garage' started by landSurfer, Jan 15, 2018.
  1. landSurfer
    landSurfer Adventurer
    Nov 13, 2017
    47
    San Diego
    I bought a used Ricochet skidplate and hope to mount it to my f650gs twin 2009. Didn't come with mounting hardware and BMW wants $$$ for theirs, so would love to NOT give them that unearned cash.
    Coupla questions for the braintrust here:
    - another inmate directed me to McMaster-Carr for their MUCH less expensive anti-vibe mounting studs here. Q: Wondering if they're the same dimensions as BMW's (some others here have used them, but may have cut them to size)
    - Related to this, I'm looking for an online source of actual dimensions for BMW's OEM mounting hardware (I've found fiche illustrations but no dimensions); anyone know of a good dimensions source?
    - Wondering if McMaster's mounts, being zinc-plated steel, will be okay re: mixing dissimilar metals (they will thread first thru the aluminum skidplate, then into the engine sump).
    Thanks in advance,
    -j
  2. tbas3
    tbas3 Been here awhile
    Mar 19, 2008
    597
    Nova Scotia
    I would not worry to much about dissimilar metal corrosion unless you plan on riding a lot in salt or regularly dipping the bike in seawater.
  3. the_gr8t_waldo
    the_gr8t_waldo Long timer
    Feb 28, 2006
    2,743
    tacoma warshington
    you'll not likely find the fastener sizes other then by measuring the plate for yourself, the bmw fiche will indicate the fastener head/style. mixing metals wil not be an issue. most any fastener that you can find will also be available in stainless( a much better looking metal than the blue flash that is zinc electro plating, or hot dipped , imho) cutting bolts isn't all that hard( just tedious) so I wouldn't be overly concerned with over length. I would use nyloc stop nuts WITH blue thread locking chemical.
  4. Trailrider200
    Trailrider200 Long timer
    Nov 2, 2010
    1,256
    Exit 10A, RT 42
    aluminum and steel are not dissimilar for corrosion. any corrosion is what the sacrificial zinc is for. anti-seize the bolts.
    Bigger Al likes this.
  5. nbsdave
    nbsdave Been here awhile Supporter
    Jul 26, 2012
    699
    sarasota, fl
    if all you need are bolts
    just hit the Ace Hardware and grab some stainless bolts/nuts/washers. Or use nylon lock nuts.
    I just don't like zinc plated.
  6. landSurfer
    Nov 13, 2017
    47
    San Diego
    Thanks, all. I've got what I need here. Sure appreciate it...
  7. kantuckid
    kantuckid Long timer
    Nov 29, 2007
    9,947
    Kentucky-Eastern that is!
    If by "dissimilar metal corrosion" you actually meant galvanic action, no salt is required for that to take place...:lol2
  8. tbas3
    Mar 19, 2008
    597
    Nova Scotia
    Dissimilar metal corrosion is a term we use in my line of work. While you are correct no salt is required for it to happen it will greatly increase the rate at which it happens. You can get away with a lot on a plane that lands in fresh water. Put the plane into salt water and the rate of corrosion will go up. For normal motorcycle usage you can get away with the cheap zinc plated hardware. If you like to ride in the winter like some do the salt makes his choice of hardware more important.
    #8
    kantuckid likes this.
  9. flei
    flei cycletherapist
    Apr 1, 2013
    10,935
    Western Mass.
    imo, this is NOT correct in this particular application. you should use the rubber isolators; if you do not and the skid plate is bolted directly to the engine case, if you get a hard hit on the skid plate it may shear a bolt, or worse, break the case. also, as far as i can tell, the MM-C parts are identical to the stock bmw parts (i am on my second set of them). and yes, it is a good idea to put anti-seize on the threads where they screw into the case so if/when the rubber shears off and you need to replace them you can more easily get them out.
    #9
    Boatman likes this.
  10. landSurfer
    Nov 13, 2017
    47
    San Diego
    I'm with Flei on this. BTW Flei, I passed on your McMaster-Carr (McM-C) tip to Don who makes the Ricochet plates in Utah; he couldn't believe the price compared to BMW's.
    I recv'd your recommended parts today from McM-C (ordered them last night!) and was surprised to note the threaded components on each side of the neoprene bushing move independently of each other. I'd assumed it was a single threaded thru-rod, but not so. So this gives extra fore-aft flex as well as vertical compression. On my low (relative to the f800gs for example) f650GS I'm losing clearance by putting on the skidplate, so expecting more dings and so I'll buy some extra bushing-mounts for backup from McMaster-Carr.
    Man, I'd love to see a MM-C option for every one of these expensive lil' BMW parts; what a useful spreadsheet that'd be for many of us!
    #10
  11. flei
    flei cycletherapist
    Apr 1, 2013
    10,935
    Western Mass.
    I also have an f650gs (twin) with the Ricochet skid plate. I have ridden it for 5 years (about 35K miles), and it has taken quite a few very hard hits. Twice i have bent the plate a bit and sheared off a couple of the rubber mounts, but the plate has prevented any damage at all to the bike. IMO the Ricochet plate has saved my ass and is a bargain.
    I also have often bought replacement hardware for the bike from MM-C if the bmw parts were over-priced, which they often are. i find that the A & S Cycles parts fiche is the easiest place to check out what you need (https://www.ascycles.com/BMW-Motorcycle-Parts-Fiche). I also do buy from A&S since their prices are less than most BMW dealers and there is no charge for shipping with no minimum, and they ship fast. I highly recommend them.
    #11
    landSurfer likes this.
  12. ericrat
    ericrat Long timer Supporter
    May 18, 2007
    1,634
    Cincinnati, OH
    I wouldn't want a skidplate without the rubber isolation dampeners.
    Max's site is great for pictures. http://www.maxbmwmotorcycles.com/fiche/DiagramsMain.aspx?vid=55255&rnd=07242017
    The parts fiche lists the isolators as M8
    Here is a picture with a ruler, again from Max's site.
    http://www.maxbmwmotorcycles.com/fiche/NotesParts/11117682158_3_B.jpg
    Something like this might work.
    https://www.mcmaster.com/#rubber-isolators/=1b6pj2e
    It is too darned cold out to go outside and remove my skidplate to measure!
    #12
  13. chasbmw
    chasbmw Long timer
    Feb 19, 2006
    3,680
    Bath Uk
    A cheap thread gauge is invaluable, tells you what diameter the bolt is and the thread Pitch.
    #13
  14. ohgood
    Sep 21, 2010
    10,052
    alabama
    use anti-seize or loctite.
    that's wayyy too much wondering/worrying for a skidplate fastener.
    #14
  15. ericrat
    May 18, 2007
    1,634
    Cincinnati, OH
    Not when the only mounting on the skidplate is into blind, threaded holes in the engine case.
    This thread might be better placed under Parallel Universe. http://advrider.com/index.php?forums/parallel-universe.77/
    #15
  16. ohgood
    Sep 21, 2010
    10,052
    alabama
    OUCH that's a dumb design. Might better use low strength studs in the case and carry spares.
    #16
  17. H96669
    H96669 A proud pragmatist.
    Nov 20, 2009
    5,952
    Hiding off Hwy 6, B.C.
    Ok
    I wonder? Same seized up/broken and degraded rubber parts I had to extract from my friend's 05 1200 GS?Wasn't exactly easy but replaced with same BMW part$.However took care of the BMW mounting that took 3 wrenches of different sizes if just to remove that skidplate for a simple oil/filter change.:lol3
    #17
