    Dismiss Notice
Zip tie tire change
Discussion in 'The Garage' started by Andyvh1959, Sep 15, 2019.
  1. Sfcootz
    Sfcootz Necessary evil Super Moderator Super Supporter
    Jun 21, 2013
    27,804
    kakistocracy
    Zip tie hasn't always worked for me. I've had a couple of super stubborn 19" fronts that required chanting and incantations in addition to zip ties. But it has been just the thing a couple of times.
    #21
  2. Bovino
    Bovino Been here awhile
    May 11, 2013
    870
    Spain
    Just don’t forget the lube.
    #22
    TonyKZ1 likes this.
  3. bv11
    bv11 Been here awhile
    Nov 21, 2011
    346
    Midwest
    I've changed 30 or 40 tires with zip ties. Michelin tires seem to practically fall on to the wheel with no effort. I have been able to mount every other brand without tire irons except Metzelers. Good lube makes it easier, but even using tire irons to get the last little bit is a breeze. I use a small screwdriver to unlock the zip ties and I think I'm on my third set.
    #23
  4. Andyvh1959
    Andyvh1959 Cheesehead Klompen Supporter
    Feb 16, 2012
    4,198
    Da frozen tundra eh? 1.5 mile west of Lambeau
    I agree. The Michelin Pilots came off pretty easy. The Metzeler Roadtec took a bit more effort. But the zip ties definitely made it MUCH easier.
    #24
  5. mouthfulloflake
    mouthfulloflake Not afraid
    Aug 21, 2008
    32,721
    The Berkeley of Arkansas
    r1200GS
    Tourance front tire.
    10 zip ties and a long tire tool and I cant get the tire off, the wheel is free spinning inside the tire, but I am unable to squeeze the tire off of the rim
    I guess I am waiting on rim protectors.
    stupid mag wheels.
    #25
  6. PineLaneRider
    PineLaneRider Long timer
    Dec 25, 2016
    1,267
    Between Michaux and Tuscarora State Forests
    Cut up milk or oil jugs are a good make shift wheel protector. Also at least 2 tire irons.
    #26
  7. JensEskildsen
    JensEskildsen Long timer
    Mar 24, 2009
    2,302
    Denmark
    Cut up a plastic jar (antifreeze, sprincler fluid ect) or cut of some gardenhose, slice it in half and use that as a rimprotector.
    #27
  8. victor441
    victor441 Long timer
    Jul 27, 2009
    2,857
    Sonoma Co., Calif.
    I don't bother with the zip ties when removing a tire, only when installing it and only then if it has a tube...but in that case they work great and it is dang near impossible to pinch a tube that way.
    #28
  9. mouthfulloflake
    Aug 21, 2008
    32,721
    well I can tell you they dont work on a Tourance radial on a 19 inch rim, ended up with a grinder to cut it off.
    ive done dozens of motorcycle tires, never had a struggle like that.
    edit- just put 9 zip ties around a bias ply 110/80/19 Shinko 705 front tire.
    it wont squeeze over the rim either.
    apparently this is a wheel/tire profile that doesnt jive well with the zip tie magic.
    Ill try the zip ties on the DR650 tires soon, maybe they will be helpful there.
    #29
  10. Beezer
    Beezer Long timer Supporter
    Oct 26, 2004
    9,996
    Anchorage, formerly Spenard (hub of the universe)
    I use tie straps
    #30
  11. foxtrapper
    foxtrapper Long timer
    Sep 6, 2011
    4,540
    Zip ties and tubed tires are a wonderful combination.
    #31
