    Dismiss Notice
Zip ties to fix a flat?
Discussion in 'The Garage' started by DurtKlod, Jul 26, 2011.
  1. DurtKlod
    DurtKlod Long timer
    Jan 15, 2011
    1,574
    Solsberry, IN
    Hey guys I've been following several of the TAT threads and have noticed the reference to zip ties several times as a remedy to flats. It seems you use them to attach the tire to the rim to keep from ruining the tire after a flat but I've not found any more elaboration on how to do it or why this works. Anybody care to elaborate? Thanks.
  2. no5s
    no5s Terror at 2 mph
    Oct 24, 2004
    382
    Oceanside
    I've used heavy zip ties on trials bikes before to keep the flat from rotating on the rim. It worked to finish on time, just not very well. Fix it if no time constraints, save your rim.
  3. showkey
    showkey Long timer
    Jun 25, 2007
    2,443
    Wausau
    Zip ties around the inner tube to seal the off the damaged area is a known trail side fix.
  4. Barman
    Barman Way Offline
    Apr 16, 2011
    1,166
    Saratoga Springs, NY
  5. Bronco638
    Bronco638 Nobody Home
    Dec 1, 2004
    5,694
    Elk Grove Village, IL
    It's more of an emergency fix if you're in a place where you cannot repair the flat. Using big zippies will keep the tire from rotating on the rim (as previously mentioned) and tearing the valve stem out of the tube. I rode a portion of the TAT (OK, NM & CO) and cannot think of any place where I could not have fixed a flat. I also chose to run rim locks instead of using zip ties. I did not have any flats while on my ride. However, big zip ties can be used for other things beside flats... :D
  6. Strong Bad
    Strong Bad Former World's Foremost Authority Supporter
    Oct 29, 2007
    11,726
    Omicron Persei 8
    Not a fix, not a remedy, only a way to LIMP back to civilization keeping the tire on the rim. You will damage the tire, but you will do less damage to the rim if it can be protected (with the tire zip tied to it) while you are self rescuing. Rim locs prevent the tire from spinning on the rim while inflated (typically while using low tire pressures). Once riding on a flat tire, rim locs quickly losen and do little to keep the tire in place. Running on a flat will also loosen all of your spokes in a hurry too.
  7. Crisis management
    Crisis management Latte riders FTW!
    Feb 14, 2007
    2,067
    New Zealand
    You're right there, shredded tube and 4 loose spokes from a flat on a trail ride last weekend (riding on sand so I didn't notice till I got back to the carpark, and how the hell do you get a nail in your tire in the middle of 2000 hectares of pine forest?).
    Why would you bother with a zip tie fix tho, it would be quicker and less damaging to simply fix the flat?
  8. Strong Bad
    Oct 29, 2007
    11,726
    Omicron Persei 8
    Like I said, zip tying a tire to a wheel is a self rescue technique. It is a last resort where you have used all of your patches/spare tubes/whatever. When racing in the desert (typical weekend 80 to 100 mile events), it is not common to carry tubes/patches or tire tools, and if you get a flat you simply ride the last mileage back to the finish line on the flat. It is not uncommon when riding on a flat for any distance at all, for the rim locs to come loose, and the tire come off the rim, with no spares/tire tools, many will try to ride in on the bare rim. It doesn't work for long as the spokes all come lose and the wheel comes apart. I've seen guys riding in on bare rims dozens of time over the years.
    #8
  9. Crisis management
    Feb 14, 2007
    2,067
    New Zealand
    I can understand the racing scenario, the question was really about the OPs' question, riders on the TAT, surely they would have planned on fixing a flat?
    #9
  10. DurtKlod
    DurtKlod Long timer
    Jan 15, 2011
    1,574
    Solsberry, IN
    Hmmm. Learn something new everyday. Okay, thanks guys. I carry zip ties but none that big. Time to go shopping I guess. I've seen a few as well (on TV) come limping in to the checkpoints on bare rims.
    #10
  11. Bronco638
    Dec 1, 2004
    5,694
    I certainly was prepared to fix a flat on the TAT (and all my other adv. rides). But, I did carry big enough zip ties that if I had to use that method, I could have.
    #11
  12. MarylandStrom
    MarylandStrom Long timer
    Dec 7, 2007
    1,224
    Beltsville, Maryland
    #12
  13. Skippii
    Skippii Milkshakes, my lad.
    May 11, 2008
    6,683
    Richmond, Va
    #13
  14. HapHazard
    HapHazard Be Kind - Rewind
    Dec 30, 2009
    5,622
    Central CT
    Redneck Bib Mousse!:lol3
    #14
