    Dismiss Notice
Zip Ties
Discussion in 'The Garage' started by Yellow Pig, Jan 14, 2017.
  1. JimVonBaden
    Feb 11, 2005
    92,087
    Alexandria, VA
    Agreed. I have never seen a real difference between cheap and expensive. Zip ties are not supposed to be mechanical fasteners, so even cheap ones are fine. Good cutters will prevent sharp edges, cut across the length.
    #41
  2. Buccleuch
    Buccleuch I'm just a bean, trying to get some sleep... Supporter
    Apr 3, 2008
    2,403
    DFW, Texas
    In our telecom offices, we don't use zip ties. We use waxed lacing cord and lacing tape.
    Why? If you have to get into cable management for new work or re-work, zip ties will turn your hands into hamburger. Cable lacing is the elegant way to do it.
    W.A.
    #42
  3. dtysdalx2
    dtysdalx2 Only a matter of time.
    Aug 1, 2004
    26,460
    Moneyapolis, MN
    This is not JM. We want some useful info here, not this BS. :stfu
    #43
  4. lesman
    lesman Live easy, Brake Hard
    Sep 7, 2006
    4,023
    Baja Okahoma
    I guess it's time to shut down the thread.
    #44
    kwb377 likes this.
  5. JimVonBaden
    Feb 11, 2005
    92,087
    Alexandria, VA
    Two different applications.
    Also why I mentioned how to trim them. If done right they are not sharp.
    #45
  6. JimVonBaden
    Feb 11, 2005
    92,087
    Alexandria, VA
    #46
    JCool likes this.
  7. JCool
    JCool Long timer
    Oct 15, 2016
    3,686
    How does this handle UV ?
    #47
  8. Strong Bad
    Strong Bad Former World's Foremost Authority Supporter
    Oct 29, 2007
    11,725
    Omicron Persei 8
    It's not the Zip tie's fault you get cut up into hamburger, it's the guy who trimmed them with anything except "flush cuts".
    #48
    JimVonBaden likes this.
  9. lesman
    Sep 7, 2006
    4,023
    Baja Okahoma
    I've seen some really "Neat" cloth covered wiring with cable lacing. It's amazing that I poo pooed cloth wiring when I young. Now it's just cool.
    #49
  10. shovelstrokeed
    shovelstrokeed Long timer
    Jun 20, 2003
    5,708
    6South Florida
    The short answer is, it doesn't. This method is as old as electrical wiring and is used in places that are not directly exposed to light such as panel boxes and control cabinets. You might see it in high end scientific equipment. It is labor intensive but wonderful to run into as repairs/modifications to the harness are fairly easy to accomplish.
    I find this whole discussion is kind of silly. UV tolerance aside, bundling wires gets to be a PITA no matter how you do it. Zip ties, no matter the brand, eventually fail, they are easily replaced when they do fail if the original installer paid attention. For years, I was able to obtain drop offs and chunks of multi-conductor cables in everything from 12 gauge to 22 gauge in lengths of up to 6 feet and numbers of conductors from 2 to 40. 6 feet of 28 conductor, 18 gauge wire would wire almost an entire motorcycle. I used scrap welding cable for the battery and starter wiring and other scraps of 14 and 12 gauge wires to handle lighting and charging loads. For my own bikes, I would make a harness board out of scrap plywood and 8d nails leaving an extra 6" or so of pigtail where I planned to make connections. The whole held together with temporary zip ties until I could do a proper wrap on the entire thing, removing the zip ties as I completed the wrapping.
    I haven't had to do this for quite a few years now as I don't bother with farkles all over the bike. I do have a tank bag floating around the house into which I incorporated a bunch of accessory functions such as connections for heated gear, head phones, GPS power and cell phone charging, etc.. When it became too much of a PITA to unplug all the crap as I dismounted the bike I just simplified my life and got rid of all the crap.
    #50
  11. tag3
    tag3 Doofus
    Jan 17, 2014
    16,407
    Inland from the coast of Santa Cruz and Trona.
    If you want to get some serious tension on your zip ties, get one of these from the bicycle trade.
    #51
  12. broncobowsher
    broncobowsher Long timer
    Apr 21, 2010
    4,296
    Baking in AZ
    What is that?
    #52
  13. lesman
    Sep 7, 2006
    4,023
    Baja Okahoma
    PARK TOOL BT-2 CABLE STRETCHER 4th hand cable stretcher
    What a cool tool.
    #53
  14. JCool
    JCool Long timer
    Oct 15, 2016
    3,686
    It was a rhetorical question.
    #54
  15. RonKZ650
    RonKZ650 Been here awhile
    Jun 11, 2009
    983
    Lakewood, CO
    The Panduit GS2B cable tie gun works great as well, but man the inflation has hit that tool. Sometimes used ones on ebay can prove worthwhile. Forget new any more for $200 or more.
    #55
  16. thetubespoke
    thetubespoke Been here awhile
    Dec 28, 2014
    798
    Fort Collins, Colorado
    Depending on what you are looking to tie, I'm very fond of Nite Ize Gear ties: http://amzn.to/2iTTyrC
    While I'm sure they don't last forever, I've never had one fail. I used one as hood ornament on my 4Runner for months in the sun and it's still fine. Makes more sense for commonly removed applications versus permanent, of course.
    I think plastic zip ties will generally fail, although it seems the good ones can last 20+ years and a few removals. I like the steel ties with rubber coatings that a lot of OEMs used.
    These may be similar, or at least worth a try: http://amzn.to/2jHNEhk
    Should definitely not fail from UV or heat.
    #56
    Yellow Pig likes this.
  17. Ricardo Kuhn
    Ricardo Kuhn a.k.a. Mr Rico Suave
    Sep 20, 2001
    17,305
    Minneapolis (don't even ask how i end up here.
    NOT for EVERYTHING.....
    But bicycle bicycle toe straps are some of the most functional methods, the main problem is to find some of decent quality since toe straps are passé for the last 40 years...
    #57
  18. triplenickel
    triplenickel Long timer
    Jul 9, 2008
    2,889
    Campbell River, BC. Fantasy Island
    Best by a mile.
    #58
  19. Sabre
    Sabre PrĂȘt? Allez! Supporter
    Nov 13, 2004
    15,264
    NW Washington State
    It's easy to offer an alternative explanation, to differ with someone else's opinion, without attacking that person. Mean people suck, right?
    Oh, and the addition of carbon black to various plastics is a primary means of adding UV protection. Your photography analogy does indeed apply to infrared, though. Cheers!
    #59
  20. Ricardo Kuhn
    Sep 20, 2001
    17,305
    Really weak zip ties (the snap just by looking at them)
    But as a toddler toy they are fantastic, mayor points in manual dexterity.
    #60
