    Dismiss Notice
Ziptying a Spare Tube?
Discussion in 'The Garage' started by outty, Mar 14, 2018.
  1. nickguzzi
    nickguzzi Long timer
    Feb 17, 2010
    8,929
    below the sea
    If you are using tubes then you will have old tubes to cut up into rings to make big elastic bands.
    These were used for all sorts of things in the old days - from cinching your leggings from flapping before velcro or nylon webbing to holding your trials number onto the bike and sandwiches on the back of your seat.
    All my wet weather kit is rolled and stashed with cut up inner tubes, and has been for the last nearly 30 years and approaching 200,000 miles.
    Inner tubes will hold another tube well, with little risk of abrasion or coming loose - they have lots of friction.
    You can also loop them together to make a long strap to make like a large temporary bungee cord.
    I think it is a good idea to rotate these spare tubes too. Relying on the tube that has been folded up and fixed to a bike somewhere for the last 5 years is not a guarantee of getting home tonight. The spare tube goes on with a new tyre, the new tube goes into back-up.
    I think it's 3 punctures in the last 30 years, and only one more before that, 1966, I think.
    #21
    Bigger Al likes this.
  2. c_m_shooter
    c_m_shooter Ninja Warrior Supporter
    Feb 25, 2009
    949
    Paradise, TX
    I fold the tube so the valve stem is out, then put it in an old sock. The sock helps keeps holes from being rubbed in it and gives you something to wipe your hands with after fixing a flat.
    #22
  3. bwringer
    bwringer Gimpy, Yet Alacritous
    Jan 22, 2008
    3,208
    Indianapolis
    Tubes deteriorate pretty quickly when exposed to sun, dirt, or even a hint of ozone. Wrap that rascal.
    Talc, tube bag, and inspect/replace at least yearly.
    #23
    nickguzzi likes this.
  4. outty
    outty (☞゚ヮ゚)☞
    Feb 4, 2018
    323
    Edmonton, Alberta
    I like the idea of using the spare tube when you change to a new tire, then using a new tube as a spare - your spares are never going to be very old.
    #24
  5. REALGRAVEROBBER
    REALGRAVEROBBER LEAVING GRAVES EMPTY
    Nov 1, 2008
    878
    GFY, Montana
    White trash bag secured to the outside, taped TIGHTLY with clear plastic packing tape (keeps the tube from rotting, chafing, and is easy to find if it falls off of your bike, etc.
    #25
