1. eNewsletter Sign Up
Zumo 220?
Discussion in 'GPS 101 - Which GPS For Me' started by NorCal.matt, Apr 23, 2011.
  1. xymotic
    xymotic Long timer
    Jun 20, 2008
    8,370
    Federal Way, WA
    Yeah, that recalc drove me batshit crazy when I was on the oregon discovery route. There are sections with dozens of roads many that don't connect and the thing would re-route me 50 miles to go 500 feet. I didn't realize it when I programmed the route and didn't have nearly enough via points. But then again, 200 per route and what 10 or 15 routes when you start heading across multiple states on dirt roads you run out of routes quickly. PARTICULARLY since you need a whole nuther route to go the other way:bluduh
    Garmin took pitty on me and took my third Nuvi 550 and $150 in exchange for a Zumo 550. This year I think I'm still going to overkill it and I'm going to load City nav, and openstreetmaps on the Zumo, and I'm seriously considering adding a 76c or delorme or a lowrance Baja as well.
    #21
  2. Twohondas
    Twohondas Long timer
    Aug 25, 2005
    1,283
    San Diego
    Zumos have City Nav already loaded and the Z550 can take Topo on the card.
    #22
  3. tbirdsp
    tbirdsp REMF
    Mar 22, 2002
    8,944
    Nebraska
    I've been happy with the Nuvi 500 for street riding (I have a 60Cx if I need to do tracks). FYI - the 10 route limit is deceiving - you can store pretty much unlimited routes on the microSD card in .gpx files and import them as needed. You just need to delete some from the 10-route memory to make room. And any that you delete can be reloaded later if you need them.
    I don't really blame Garmin for not letting you reverse a "follow roads" autoroute. If you have vias on one side of 4-lane divided highways it will go nuts.
    #23
  4. ZXMorty
    ZXMorty Been here awhile
    Oct 10, 2010
    374
    Zeeland, MI
    I bought a used Zuma 220 from an inmate and I have had a few problems. First the wire direct harness didn't work so I had to use the 12 volt power plug. It worked fine that way a couple of times. Now for some reason when plugged in with power it won't switch from internal battery to 12 volt. I used it this past weekend and it had me put on an extra 30 miles out of the way. Anyone have a clue what is going on with the power issue? It also won't bluetooth with my Iphone. Overall not very happy with the purchase.
    #24
  5. xymotic
    xymotic Long timer
    Jun 20, 2008
    8,370
    Federal Way, WA
    Well, the easiest solution is to check the plug tip and see if the fuse has blown.
    #25
  6. ZXMorty
    Oct 10, 2010
    374
    Zeeland, MI
    Done that, when plugged into a power outlet the green power light comes on. It's getting power, but wants to only pull from the internal battery which is almost dead.
    #26
  7. RidingDonkeys
    RidingDonkeys Purveyor of Awesome Supporter
    Oct 23, 2009
    14,488
    Santiago, Chile
    This GPS research is making me crazier than batshit. But let me see if I get this right:
    You cannot turn off auto-reroute on the Nuvi 550.
    You can turn off auto-reroute on the Zumo 220.
    Is that right?
    Also, can anybody comment to route planning on the Nuvi 550 versus the Zumo 220?
    #27
  8. eram310
    eram310 Been here awhile
    May 22, 2008
    102
    Minneapolis
    I have had the 220 for several months now and it is a good GPS. It is an upgrade from my old Quest. It doesn't do tracks (I have a 60CX for that) and i do not use the blue tooth feature, but I know it has it. I can turn auto calc off. Something you can't do with the Nuvi 500/550.
    #28
  9. Orangeshirtdude
    Orangeshirtdude Fight the Power Commander
    Aug 15, 2009
    65
    Ellicott City, MD
    I'm seriously considering the Garmin Zumo 220 because I can get a new one for about $400 compared to at least $200 more for a 550 or 6xx. I do not like to listen to music while I ride. Plus I'm on Sprint so as soon as I get out in the hills of West Virginia, it's game over for incoming calls. Even if I had signal, I don't want to talk on the phone anyway. Therefore, bluetooth to the extent that I can run a wireless earpiece is enough for me. Seems like a good little unit for motorcycling.
    #29
  10. matts1050
    matts1050 V Twin Guy-Just Turned 90 Degrees
    Nov 21, 2007
    457
    Bethel, CT
    I should have my 220 in a few days. What is auto calc? Also, I would like to use the bluetooth but don't use any comm devices except the bluetooth for the TPX radar detector. Is there a simple bluetooth receiver that I can use-something like the hands free earpieces but that will fit into a helmet?
    #30
  11. SF_Rider
    SF_Rider Been here awhile
    Feb 2, 2011
    450
    I've been using my iphone as a gps unit for a few months now. It works really well with programs like motionX. However, when you lose your cell signal you lose your maps. It's still great if you worry about getting lost as you can always follow your track backwards and get out. However, I want to see the maps/forest roads/topo when I'm going. Also, if you crash and crush the iphone you are without gps or phone (which I realize may or may not have service).
    So, I am interested in the 220. The newer ones only interest to me are the larger screens. I do not need or want any of the blue tooth/music stuff.
    Anyone using the 220 and using it off road with a purchased topo map? Good/bad/ugly?
    thanks
    #31
  12. RidingUpAndDown
    RidingUpAndDown Been here awhile
    Aug 21, 2011
    121
    Central MAss
    I'm fairly new to the Zumos, have a 60csx used mostly for geocaching, and in my research the Zumo 220 would probably appeal to the riders (as in my case) that want something a little more affordable than the $600-700 of the 550 and other Zumos. Have also unlocked the Topo from the 60csx now on the Z-220.
    Z-220 like all the Zumos is 'made for a motorcycle'; shock/vibration/water-proof.
    Check out the comparison, link below, it has close features to the Z-550. I personally don’t need the MP3/XM or to pair w/ a cell phone/allow hands free calling, which are the only real differences and things I would not need/want anyway, imho.
    I also have the Scala G4 comm devices for talking among riders/passengers, and they do the BT MP3/FM/Cell, so is reason I don't need that on the Z-220. I BT the Z-220 to the Scalas, very nice combination, and ride happy.
    Compare Zumo 550 and Zumo 220 - https://buy.garmin.com/shop/compare.do?cID=135&compareProduct=65210&compareProduct=414
    Zumo-220 I've seen for around $340-$360 is a pretty good deal, relatively.
    .02 :ricky
    #32
  13. Maartensworld
    Maartensworld Adventurer
    Dec 22, 2010
    38
    Samaipata, Bolivia
    Test garmin zumo 220
    I have owned and used a lot of Garmin GPS’s and was always very satisfied with the device and with the service of Garmin.
    But something has changed.
    My last purchase was a Garmin zumo 220. Water and shock resistant designed for motorcycle use.
    I checked several reviews and was convinced that this was the best choice for me.
    However, my joy did not last long.
    The first device I received only worked for 2 days. After this, it refused to switch on without a screen-calibration. Not that it told me this in any way. No, after switching on, it simply switched off again. It took me well over an hour to figure it out, but when you place your finger in the left upper corner of the screen when turning the device on, it starts in “calibration mode”.
    It turned out that the firmware was out-dated and needed to be flashed. OK, this is easily done, but I wonder why does Garmin sell devices that don’t even work until they have had updated software?
    After this was done the device worked, as I thought, pretty well. However, it did (does) have several very, how shall I put it gently, extremely stupid blunders in the software, mostly when in metric mode. I would therefor conclude that these stupidities are a result of adjusting the software for metric use, when it was first developed for imperial measurement. Maybe I am wrong, but this is my impression since no one is dumb enough to develop a device with the following features:
    For instance, the altitude is displayed in, believe it or not, whole kilometers. As long as you stay below 1.000 meters, it is fine. But in the range of 1.000 meters to 1499 meters, it tells you happily: you are now at an altitude of 1 Km. From 1500 meters up to 2499 meters you are, surprise surprise, at 2 Km altitude. And so on. Apparently Garmin thinks that an accuracy of + or – 500 meters is of no great concern.
    Another great feature is the build in fuel-meter. Very useful as most endure-bikes do not have fuel-meters, but do have small fuel-tanks.
    Unfortunately the fuel gage is completely unreadable because the remaining distance in kilometers is written across it. Alas, in a font-face that is too small to read while sitting on a motorbike.
    Again, in imperial-measurement things work slightly better as the word “miles” takes a lot less space than the world ”kilometers”. Luckily you can turn off the fuel gage.
    The Zumo 220 has several “user modes”, such as “driving”, “motorcycling” and “walking”. Nice idea, as all have their specific speeds and needs.
    Too bad that Garmin seems to think that if you are riding your motorcycle and you come upon a traffic-light, you want to jump off your bike and start walking. So it offers you a screen (which completely blocks out the navigation screen you were using to find your way in this frantic city, rush-hour traffic) to ask “do you want to switch to pedestrian mode?”. Now, while throwing your bike from left to right to get past the grid-locked intersection, you have to press a button (yes or no) so you can see your navigation screen again. (Funny thing is that when you are cruising on a deserted highway and want to press a button, it tells you this is not allowed cause it is dangerous. Then asks you if it should disengage “safe mode”, where you press yes, and then you can press the button of your choice. (So now you have pressed 3 buttons and had to read a reply)
    Anyway, you have your navigation screen before you again and are searching and navigating while weaving through traffic. All is well, until the next traffic-light, or even the next “slow moving traffic jam”. Again the device hides the o so needed navigation screen and asks you again “do you want to switch to pedestrian mode”.
    This goes on and on and believe me, your Garmin GPS can do this all night long.
    When on a trip, the odometer is a very useful piece of equipment. And naturally every GPS has one… except the Zumo 220. No, no way to see how many km (or miles if you please) you have done. This is too bad since you disabled the (useless) fuel gage, and was calculating yourself how many km (or miles if you please) you could do. Too bad you can’t see what you did, so you’ll be pushing your empty bike back home.
    Planning a nice day, or more days, in advance on your “mapsource” or “basecamp” program.
    Planning is half the fun. Then transferring the route into your Garmin and off you go.
    I am sorry, but no. You cannot simply upload (or download) the route into your Zumo 220. That is, you can do this, and there will be not one single error or guiding message, but if you think that is it, you are sadly mistaken as your route is nowhere to be found.
    After searching for several hours I found out that any “up-loaded” route is stored in a separate file on your Zumo’s memory card. Now, under the menu-choice “tools”, and then “my data” you can “import route from file”.
    OK, so it takes a bit more work to do this, but I am not in a hurry, you think. Alas, wrong again. The route you so carefully made, saved, and downloaded to your Zumo 220, is nothing but a series of waypoints (sometimes only “start” and “finish”. Now your Zumo goes to work and calculates a nice route out of this. Yes, you guessed right, the result is nothing like the route you made. And if you are really out of luck, it is just a few straight lines from start to finish.
    Saving a waypoint (poi) used to be easy. Now you have to “tap the screen” (exactly on the indicator) or go to “menu”. Then “tools”, then “where am I”. Then save location, give it a name, go to back to menu (two buttons to press), then go to “where to”, scroll down until you get to “favorites”, find your newly added POI amongst all your other POI’s (I have hundreds), tap on it, then choose “edit”, and only now you can assign a screen-icon (map symbol), a category or change its name.
    And none of that is easy because for some reason (please don’t ask me why) Garmin decided to give the Zumo 220 a “non qwerty” keyboard. So you’ll spend a lot of time searching for the letter you want to type. And why? Programming an ABC or a QWERTY keyboard is exact the same amount of work, costs exact the same amount of money and takes exact the same amount of screen-space. So, I am flabbergasted about the reasoning behind this.
    Then again, what can you expect from people that show you the altitude in whole kilometers, block out their painstakingly made fuel gage with small letters and let your routes disappear in an electronic black hole?
    Anyway, back to my Zumo 220.
    Since I was used to Garmins expert and correct service, I contacted them and explained about all these silly inconveniences. At first Garmin replied that I could send in “suggestions” and they would eventually fix all these issues. Isn’t that great.
    Alas, after sending in all my suggestions, I received a reply that, to my great surprise, stated that the Zumo 220 was a discontinued device, and that there would be no more software upgrades.
    This kind of “stung” me because I had just bought it and no one had told me it was or would shortly be “discontinued”. When I checked the Garmin website, the surprise grew… as there still was no mention about being discontinued. (And now, almost a year later, still not).
    But… I cried silently and accepted the fact that I was stuck with a U$ 400.= piece of junk. At least I could see on the map where I was and where I was going.
    As I said at the beginning: “The first device I received…” This indicated I had more. And so be it.
    After several months of service my Garmin Zumo 220 decided to come up with a neat trick. After some 5 hours of being switched on, it would spontaneously reboot, go into “connected to a PC mode”, wait for a few minutes and reboot again to continue working fine for 10 minutes after which the whole story began from the beginning. Not really a workable situation.
    So I turned to Garmin. Again, again full expectations, and again painfully disappointed.
    After I explained what the problem was they told me it had to be replaced. OK, shit happens; we all make mistakes, also at QC (quality control). So arrangements were made to replace it and so it was done.
    But… to my utter disgust and amazement the device that I received (as a replacement of my 2 months old Zumo) was a second hand, refurbished device. What the ^%$#^!!?????
    So, again I contacted Garmin and was told: “Yeah, we are sorry for that, but since the Zumo 220 is a discontinued device, we have no more new ones in stock. But if you care to pay 300 U$ extra you can swap it for another model if you want…”
    I was, to put it mildly, a little bit upset with this and, just for the fun of it, I checked the Garmin website and…. Still no mention that the Zumo 220 was discontinued. I ordered one, and went all the way up to the payment-screens (naturally I did not pay fo0r another piece of junk) and nowhere was I told nor warned that it was discontinued or out of stock.
    How strange.
    So, I wrote again to Garmin to explain them this and told them that if they could not replace my “new but broken” device for another one, they should send me the next model (without asking me to pay for the difference).
    I never have received a reply on that email. I guess it must have gotten lost. It probably used a Zumo 220 to find its way to Garmin.
    After more than 15 years of using Garmin GPS’s… I can honestly say: I will never ever again buy a Garmin. If I am lost in the middle of the Sahara desert and I see someone who has a Garmin GPS for sale, I’ll ask him for a sip of water, and continue crawling through the desert.
    And why I ask.
    10 years ago Garmin dominated the market. They were the only ones with Motorcycle GPS’s
    Then, their devices and their service were fine.
    Now, at a time that you can buy a Tom Tom Rider, or a Magallan or a Teletype or a Cardo. (starting at 280 U$ for a shockproof and water resistant model) Garmin decides to “royally **** up” with this Zumo 220 and with its service.
    Well… Tom tom, here I come.
    Maarten
    #33
  14. Cattledog1969
    Cattledog1969 Been here awhile
    Mar 7, 2011
    350
    A Wealthy Cape Cod College Town
    Maartensworld, thank you for this information. I too have been reading about the Garmin Zumo 220 and I think this answers all my questions.
    #34
  15. Corsica101
    Corsica101 Been here awhile Supporter
    Jan 5, 2013
    572
    Valencia
    Have a Zumo 220 as well. No real complaints about it, always got me where I had to go but not raving about it either, quite unhandy to work with.
    I'm now looking to upgrade to something with better maps for South america.
    Any suggestions? Any opinions on the Montana series?
    #35
