Zumo 665 and City Navigator NA - Can't have all USA?
Discussion in 'Mapping & Navigation' started by Karson, Jun 25, 2020.
  1. Karson
    Karson Been here awhile
    Apr 18, 2010
    333
    AMES IOWA
    Previously, whenever I updated my lifetime City Navigator NA maps, all of the Lower 48 was an option.
    When I updated yesterday, I have to select a single region to upload. Living in one of the fringe states (Iowa), this is going to be potential a major PITA.
    Any insight before I call Garmin to clarify?
  2. ADVer
    ADVer Been here awhile
    Nov 29, 2006
    593
    Pittsburgh, PA
    Maps have become bigger and need more memory. You need to save the map to an SD card. Buy one up to about 32 GB if you don’t have one in there and when downloading the map update pick the option to download to SD card ( and computer).
  3. CRracer712
    CRracer712 Africa Twin Rocks! Supporter
    May 4, 2020
    159
    Kansas
    Get an SD card, if you don't have the option to install to the SD card such as I don't on the zumo 550, clone your 665 to the SD card. The SD card needs to be formatted to FAT32.
    This should allow your PC/Garmin express to recognize just the SD card as your 665(do not have the actual 665 connected).
    It'll update the maps in full. You can then rename the map files in the Garmin folder: gmapprom.img, gmapprom.gma and gmapprom.unl to gmapsupp.img, gmapsupp,gma and gmapsupp.unl.
    Delete all other files in the Garmin folder, and in the root directory of the SD card.
    insert card in zumo and boot. Check loaded maps. Make sure they show current.
    Once verified. It's safe to delete those 3 renamed files(original file names) from your 665 internal drive.
  4. ADVer
    Nov 29, 2006
    593
    Pittsburgh, PA
    On my Nav IV, supposedly similar to the Garmin 660/665, I did have the option to download maps directly to an SD card using Garmin Express. The 550, as you indicate, doesn’t have this option and therefore needs a workaround as you describe.
    I think he should be able to do it without the workaround.
    CRracer712 likes this.
  5. 1TrackSam
    1TrackSam Adventurer Supporter
    Jan 2, 2007
    65
    Orygone
    CRracer, thanks! I've struggled through Map Updates on my antiquated 550 for years. Your process worked like a champ!
