This guest post was kindly contributed by Michnus who originally published this article here.
Choosing the right motorcycle travel tent is a complex decision that’s influenced by where and when you camp, how many people, and also how you camp and how long. It does not matter whether most people spend less than two weeks per year camping or make it their home for months on end, it is worthwhile doing proper research when buying a tent that will be home on those epic expeditions.
The Basics:
  • Intended use: Where and in what season?
  • Structure/features: Freestanding versus stakes, vestibule, double or single-wall construction
  • Capacity: How many people and how much gear do you need to fit inside?
  • Weight: Your tent should be as light as possible while still meeting your purpose, capacity, structure and cost requirements.
  • Time travelling, how many times pitching and packing on the trip.
  • Price.
  • Important points to consider here.
    • Our current tent has now been used for a total time of more than 340 days pitching and packing it nearly every day. With time we realised what type of tent would be best for longterm motorcycle travel and the best features it would need. Motorcycle travel has its own unique challenges compared to other sports or adventures when it comes to shelters:
    • Pitch and pack tents nearly every day for weeks or months on end. They need to be hard wearing and be able to handle being pitched and packed more often.
    • Fewer parts, less to get lost.
    • Poles must be able to take stresses of being pitched continuously.
    • Be freestanding and be able to pitch quick.
    • High roof as we spend more time over the period inside tent and need the head room.
    • Livability – Must have more space and overhang vestibule.
The most suited tents for motorcycle use would be either a one man tent or a Bivy for a short trip or a one man double wall tent for long trips or the two/three man double wall tents. Most weigh less than 2-3kg and pack really compact.
Understanding tent jargon
Types of tents:
Bivy’s & tarps: A bivouac sack (also known as a bivy, bivvy, or bivi) is an extremely small, lightweight, waterproof shelter, and an alternative to traditional tent systems. It is used by climbers, mountaineers, hikers, ultralight backpackers, soldiers and minimalist campers. (wiki)
Fer-tente-bivy
Fer-tente-bivy
Double-wall tents have three parts: (1) an inner tent with a waterproof floor and non-waterproof roof, (2) a waterproof outer tent rain fly, and (3) poles. Double-wall tents come in three varieties, Self supporting or Freestanding or Tunnel tents. This combination works very well. This is in our opinion the most suited for motorcycle use. With waterproof-breathable fabrics like Gore-Tex, single-wall tents came into being. These are even more lightweight and also more expensive. If not designed properly, single-wall backpacking tents can have more condensation problems.
These tents also comes in: Front entrance, side entrance and both side entrances.
* 4-season: all-weather backpacking tents for the heaviest snow and rain, the fiercest winds, winter backpacking or mountaineering.
* 3-season: suitable for the worst weather of spring, summer and fall
* Convertibles: designed so you can leave out a pole or zip out a section or panel, converting four-season into three-season
* 2-season: generally best for mild weather conditions; “ultralight” backpacking tents often fall into this category
* Minimalist shelters: may or may not be considered a “tent”, tarps etc.
* Vestibules: A vestibule is an extension of the rain fly that goes out beyond the doorway and down to ground level. They’re extremely handy and it allows you to store your pack and gear out of the rain, without taking up room in the tent. In really bad weather, you can cook on your stove in the vestibule. That way you don’t have to worry about carbon-monoxide fumes in an enclosed tent. You can often get by with less internal floor space if you have a good-sized vestibule.
*Hydrostatic head: For any fabric to be considered fully waterproof it must be able to withstand the pressure of a column of water 1000mm high without leaking. This is classed as a hydrostatic head rating of 1000. These ratings are used to describe a tent floor waterproofness.
How to measure waterproofing
* Doors: Very lightweight tents often only has a single door. That’s fine, but 2-person tents with 2 doors give each sleeper a separate entry and exit point so you can come and go as you please. This is nice, such as, if your companion wants to turn in early while you stay up to do some stargazing or just drink more beer. Also more user-friendly than crawling into a tent like moles.
* Poles: Virtually all backpacking tent poles are made of aluminum 7001 grade alu and shock-corded together. Older or cheaply made tents use fiberglass poles, best to try to avoid. One important thing about poles, however, is the length of the sections. The longer the sections the harder they are to pack inside small spaces. Look for tents who use DAC poles or Easton poles as example you can be assured it will be a good quality tent and they used quality materials. There are plenty of other brands but these are renown for high-quality poles. Repairs: It is easier to cut an Aluminium pole and use it again than trying to fix a Carbon pole.
* Structure: Most lightweight tents these days are “freestanding”, meaning no stakes are required for setup. Non-freestanding tents often have fewer poles, so they’re lighter. Hammering poles into the ground or rocky ground can be an issue and can be a big pain. A freestanding tent also helps if you’re tired or lacking time, arriving at a campsite late … this happens more often than not. Just insert poles, throw in your gear, and ignore the slightly loose walls.
* Footprint & Groundsheets: Tent footprints are made for your particular tent model or floor shape. You place it beneath your tent to reduce wear a tear and possible ground moisture seepage. Cut a footprint from a sheet of clear painter’s plastic or buy a cheap tarp from outdoor shops. It’s cheaper, lighter, easily replaceable, and of course guaranteed absolutely waterproof.
Nigor tent
Nigor tent
* Capacity/Size: Lightweight tents are made for 1-man, 2-man and so on, but the real internal space varies. Most Chinese tents sold by Walmart or Game are more suited to small Asian postures.
The average western male will not really want to share a 2 man tent. So it’s best to look at the area specification specified. Add that you want to put your gear inside the tent.
What is the best then? In general, unless you know you will be venturing solo AND lightweight a lot, we recommend looking at the 2-person tent so you have more options or if you are two people get a 3-man tent.
* Mesh panels: This is a very important aspect for Africa or hot climates use. Tents intended for milder conditions typically make ample use of mesh. Some lightweight tents, in fact, offer all-mesh canopies—a nice place to spend a night under million stars. Mesh alleviate stuffiness inside a tent.
* Ventilation: Condensation is a huge problem in tents. If enough builds up, the moisture could pool into drops of water and will start dropping on you and your bedding. The antidote: Easy, get a tent with good ventilation.
Breathable mesh, when used in hotter climates, is a must.
* Weight: What is considered “lightweight tents? What is considered heavy? The more living space, the bigger and heavier the tent, also depending on the fabrics. So when comparing tents, look for high square meters and low weight. Don’t automatically discount a tent due to above-average weight. Internal volume and floor space may be a bonus. As well, you may want less mesh for warmth, or more poles for strength, or a larger vestibule. Everything is a trade-off. Some of the higher-quality brand 3 man tents will weight around 2.5kg to 3.5kg.
* What about height? Height is really secondary because motorcycle tents are always going to be low profile, you’ll be sitting, crouching or stooping. It is worthwhile to search for a tent with a high roof. It makes life a lot easier to live in.
* Fabric: Lightweight tent floors and flies are made from, in increasing order of performance: coated polyester, coated nylon, and cuben fiber. Cuben fiber is too expensive and we will rather leave that out. Nylon is generally stronger and more abrasion resistant than polyester. Both materials require a coating to become waterproof. A fabric’s denier (D) is a rough indicator of its weight per square area. The lightest tent fabrics are 10D, most tent floors are made of 40-70D, and expedition duffel bags are made of 650D.
  • Ripstop nylon: Woven with a doubled thread at regular intervals, it prevents rips from spreading and is often used in tent canopies. It is a touch lighter than taffeta nylon (a common, high-durability floor material) and gets used for floors in low-weight tents. The weight reduction of such lightweight fabrics is fantastic, but using such feathery fabrics requires users to take extra precautions to minimize abrasive surfaces.
  • Polyurethane (PU) coated fabrics: PU is the coating of choice for all budget tents because it is the cheapest way to achieve a waterproof fabric with reasonable durability in cold and wet conditions. Unfortunately, the PU coatings found on less expensive tents are susceptible to chemical breakup, which eventually leaves the tent non-waterproof. The best mountaineering tents and some tarp inserts have PU formulations with polyester, which makes them highly resistant to hydrolysis.
  • Silicone elastomer coated nylons: are used on all high-quality backpacking and mountaineering tents. SilNylon is highly water repellant, elastic, and UV and temperature stable. SilNylon is considerably stronger, lighter, and more durable than PU coated fabrics. It’s also much more slippery than PU. Silicone is widely regarded as the best coating for nylon fabrics used for pack tents. Unfortunately, for the budget-conscious consumer, silicone is more expensive than PU.
Nigor tents – The fabric has been constructed using high tenacity high-tenacity nylon 6.6, which has a higher tensile strength than regular and most used nylon in tent construction. The fabric has been silicone coated in three steps, resulting in the most durable and water repellent protection.
* Pegs and Guylines: A guypoint is a reinforced, patch-like area on the tent to which a guyline can be permanently attached. The guyline is then pulled taut and tied or looped to a stake. During rain, this keeps a wet rainfly from sagging onto the canopy. In wind, it can reduce a fly’s proclivity to flap. Keeping a rainfly taut and separate from a canopy aids ventilation and reduces condensation buildup. Try and use the best quality stakes possible, the low grades one will bend even in soft soil.
Pegs and guylines
Pegs and guylines
* Pole Sleeves or Pole Clips Poles?: These connect to canopies via clips, sleeves or a combination of the two. Pole sleeves help distribute fabric tension over a larger area and thus create less overall stress. Sleeves offer a stronger pitch, but, particularly during rain threading poles through them can be a pain in the arse. Pole clips are easy to attach and usually allow a larger gap between the rainfly and tent body. This improves ventilation and minimizes condensation. Clips also weigh less.
DAC Sunflower and Swivel connecting cross and the DAC Featherlite NSL aluminum shock-corded frame is about the best in the business.
* Seams and Seam Sealer: Nearly all top-brand backpacking tents today come with factory-taped seams and require no sealing of their tiny sewing holes. As a tent age, seam tape may become frayed. If so, apply seam sealer to plug any tiny fissures that appear along seams.
* Color: Why a really pimp daddy colour? One usually only needs a bright colour for an emergency and has to spend extended time inside your tent while rescuers are searching for you. Rainflys and canopies that use lighter, brighter colors tend to keep tent interiors brighter and cooler, something that can lift moods during extended tent stays. Traditionally, rainflys have featured earthy colors in order to remain unobtrusive and reduce the visual impact on the surrounding scenery. The lighter colors also keep the tent cooler inside.
* Livability: How much comfort we need and want varies highly based on our experience camping, how much time we plan to spend in our shelter and what we believe to be an acceptable level of protection from the elements. Double-wall tents are more comfortable than shelters. For motorcycle use, it is always a good idea to have packing space inside the tent in addition to the people inside.
Nemo tents Jake’s Feet corner anchors lock pole tip in place, making for an easy single person setup
* Quality Tents vs. Discount Tents: Why buy a brand-name tent when bargain tents are available at chain stores?
  • Durability: Tents designed by quality-conscious brands use better materials aluminum instead of fiberglass poles, for instance, and are built to withstand demanding use. But you need to consider the cost.
  • Design: Bargain tents sometimes use coated fabric not just on the floor but high up the walls, drastically reducing breathability.
  • Interior space: Efforts to boost wall verticality are rarely seen in bargain tents.
  • This is where you need to consider the cost.
Examples of tents most suited for motorcycle travel, longterm or short overland adventure expeditions:
AvVida
AvVida
Tents with room to park a motorcycle.
  • Just a thought on the type of tents where you can park your motorcycle in a separate part.
  • They tend to weigh the wrong side of 5kg. It does not sound like much but it is double a normal tent.
  • Those tents pack the size of a crate of beer. Which is also double the size of a normal tent.
  • If you need a tent with space, simply buy a normal bigger size tent which will still be less weight and size than those sold as bike tents.
But security? If you need security for your bike you a better off not camping at the place. The tent does not offer security. As for normal security and being obscure we have used a normal 4mx5m tarp with carabiners to cover the bikes in parking lots or just making them less visible. You can also use a dedicated bike cover. All of which cost less than the tent and have more than once use.
But a sand storm? Those tents are not going to stand in a sand storm, we saw tents blown to pieces in Patagonia and Sudan.
But I can work in a tent in the rain? You can also do that by setting the tarp as a roof over the bike in rain or to stay out of the sun.
Michnus, GenX’er born and bred South African product. Known on ADVrider for his epic ride report Michnus & Elsebie Piki-Piki Around the World. Not known to follow or believe his own advice however he loves to share stories and inspiration with others. Michnus and his better half left South Africa 10 years ago on an initial 6 month planned trip up to Europe through Africa. Sold the family pets and mom, hit the road motorcycling on a semi-permanent basis to this day.
Follow Michnus on Instagram and check out his blog here.
Some of the comments on this article is worth including into this article as an update:
  1. I use a high quality ( Mt Hardware) 2 person tent. 1/2 of the inside is my sleep space, the other 1/2 is secure/dry inside space for gears, clothes etc. Boots live in the vestibule. I’ve tried many combos and find this works best for moto travel and comfort. My tent has a ground tarp designed for it. I would never buy a tent that did not have a specific ground sheet designed for it included or extra $. It’s three season so it has a rain cover when needed or mesh only when hot and dry. I also use a 30″ wide Nemo insulated pad and a down bag. Best sleep I’ve ever had in all these years…most nights in the past sucked. The best tent in the world will not yield a good night sleep if you also have not invested in a quality pad and bag.
  2. Just a small point: it helps to use a heavy duty ground cover, like the one in the picture. Ants will pinch their way thru and move in while ya sleep. Especially in the rainy season. Found thousands of ants in my tent one morning, yukky.
    For motorcycle travel the best feature that I have found for a tent is having a large vestibule. Two people traveling together are comfortable in a 3 person tent, but a large vestibule for your boots, helmet, jacket and even your panniers is a great thing. Sure panniers are waterproof and can stay on the bike, but when you wake up and want a clean and dry pair of socks, having the paniers in a dry vestibule is a great thing. Most high quality and modern tents are made with good materials and designed in features that make life easy on the road. My hilleberg is simply the best I have ever used.
    A spectacular writeup. I’m in the business of selling tents as an outdoor retailer, and while I have staff that are actual experts, I know a couple things on this subject.
    For those of us who just don’t do a trip when its likely to rain, but are prepared for it in case the weather changes from forecasted (me), I have always used a small 2-person tent with a separate rain fly. Key is the small 2-person size, as not all tents are sized the same by all manufacturers. I like the extra space and even on my dualsport XR650R’s and KTM 350/500’s with GL Coyote bags there’s room for a tent of this size and weight.
    Certainly, if I was doing months long trips I would have a different standard, but for most of us a good backpacking tent with a separate rainfly is quite adequate. YMMV, etc.
    Kamp-rite Tent-cot. Sure, it’s huge and thirty+ lbs. But it’s a good nights sleep. I have a tarp and a pair of poles that I setup as an awning/bike shelter. Set the cot up next to the bike, lash the tarp to the wheels, throw the poles out. Wind up with with an eight foot tall awning that sticks out about six feet past the tentcot.
    It’s a big, heavy setup. That being said, the tent cot is less than five minutes in the dark, the awning is 3, in the dark and in the rain. I end up with a dry bike and a dry me. Also, the good nights sleep.
