Acronyms are everywhere. You most likely use them daily. Motorcycles are no exception. We use them to define our bikes, their systems, and other things found in the motorcycling arena.
This quiz tests whether you know some of the quite common acronyms as well as a couple of less well-known ones. Some of the definitions are pretty close to the accepted standard, so read the answers carefully. If you think that the correct answer is not shown, choose the one that is closest to what you think it should be.
Many will find this quiz easy, but few will likely score 100%. Give it a try and see where you end up.
When you are done, let everyone know how well you did. Enjoy!
