Husqvarna is announcing that their updated 701 models are now available. For 2021, both the Enduro and Supermoto models benefit from shared and model-specific upgrades. Husky says that the “…two large-displacement machines continue to offer unparalleled riding experiences both on and offroad.”
Shared updates
Both bikes get a new LCD dashboard. The dashboard now features “…an integrated gear indicator, as well as an RPM display.” Both also get a redesigned headlight nacelle that Husky says “…has been developed using extensive motorsport experience.” Lastly, each 701 is now equipped with a EURO 5 compliant exhaust system.
Model Specific updates
Enduro
The 2021 Enduro ABS is now switchable. Riders can now choose to disengage the ABS “…to unlock exceptional offroad performance.
Supermoto
For 2021 the 701 Supermoto’s braking system receives a new Brembo Monoblock 4-piston front brake caliper. Husky claims that when the new caliper provides superior stopping power in all conditions.
In presenting the new 701 models, Husqvarna provided the following:
- A New LCD dashboard with integrated gear indicator and RPM display
- Redesigned headlight unit based on extensive motorsport experience
- New EURO 5 compliant exhaust system
- New Brembo Monoblock front brake caliper on Supermoto for improved brake performance
- ABS functionality can be fully disengaged on Enduro for exceptional offroad performance
- Advanced Ride Mode functionality includes Supermoto/Offroad ABS mode
- Cornering ABS
- Lean-angle sensitive traction control
- Easy Shift
- Chromium-molybdenum steel trellis frame
- Aluminum swingarm
- Polyamide rear subframe with integrated fuel tank
- 74 hp single-cylinder engine
- Ride-by-wire throttle
- Power assist slipper clutch
- State-of-the-art bodywork and striking graphics
The 2021 701 Enduro and 701 Supermoto are available now from authorized Husqvarna dealers. Both bikes carry a $12,099 MSRP.
701 LR Dropped
If you are an owner of the longer-range Husky 701, be thankful. For 2021, the 701 LR has disappeared from Husky’s website. Unfortunately, it appears that the model will no longer be produced. Nor does it appear that a larger accessory fuel tank will be available. There’s no immediate word as to why the bike no longer appears in Husky’s model lineup.
All photo credit: Husqvarna
