Moto Guzzi rolled out a new version of the very popular V85 TT adventure bike at EICMA.  The V85 TT Travel is Moto Guzzi’s idea of an adventure machine that is ready to travel at the time of delivery.
The Italian manufacturer says that they listened to riders who wanted a V85 TT  version that comes standard with a selection of “essential adventure touring accessories”.
Standard equipment
The V85 TT Travel comes standard with equipment and accessories that are already in the Moto Guzzi catalog.  So upon delivery, the new model comes with a higher touring windshield that offers greater protection.  The new shield’s surface area is 60% larger than the original one it replaces.
Moto Guzzi V85 TT Travel
Its the same as the V85 TT but with catalog equipment that comes standard.
In addition, the bike comes with two “plastic material” panniers with aluminum inserts.  The right side pannier has a 37-liter capacity and is able to hold a full-face helmet.  The left side pannier is somewhat smaller and has a 27-liter capacity.  Both panniers lock and unlock with the same key.  Moto Guzzi wanted to keep the V85 TT Travel’s profile as narrow as possible.  As a result, the panniers’ overall width is limited to 928 mm (36.5 inches).
The V85 TT Travel also comes with heated grips which can be controlled using the machine’s original left-hand switch block.  To make sure your course is well lighted Moto Guzzi has added a pair of additional LED lights.
The V85 TT Travel from the front.
Additional technology is also a part of the package with the inclusion of Moto Guzzi MIA.  It allows the rider to connect a smartphone extending its functions to the instrument display.
Different look
To make sure the V85 TT Travel stands out from other Moto Guzzi models, the V85 TT Travel sports an exclusive
The Sabbia Namib paint is exclusive to the V85 TT Travel model.
paint scheme with black accents surrounding a grey frame.  It has quite a “desert” feel to it.
Moto Guzzi is quick to point out that the V85 TT Travel uses that V85 TT platform and that other V85 TT specifications that riders like about that machine are also included in the Travel version.  Moto Guzzi says that means the Travel version retains a range of about 250 miles and a seat height of 32.6 inches.
Pricing and availability are to be announced later.
Released specifications:
Moto Guzzi V85 TT Travel: technical specifications
ENGINE
Type Transverse 90° V twin, two valves per cylinder (titanium intake).
Cooling Air
Engine capacity 853 cm³
Bore and stroke 84 x 77 mm
Compression ratio 10.5: 1
Maximum power 80 HP (59 kW) at 7,750 rpm
Torque 80 Nm at 5,000 rpm
Fuel system Electronic injection; Ø 52 mm single throttle body, Ride-by-Wire
Fuel tank capacity 23 liters including 5-liter reserve (6.1 gallons)
Emissions compliance Euro 4
Consumption (WMTC cycle) 4.9 l/100 km
CO2 Emissions (WMTC cycle) 118 g/km
TRANSMISSION
Clutch Dry single disc
Transmission 6 gears
Gear ratio values 1st 16/39 = 1: 2.437
2nd 18/32 = 1: 1.778
3rd 21/28 = 1: 1.333
4th 24/26 = 1: 1.083
5th 25/24 = 1: 0.960
6th 27/24 = 1: 0.889
CHASSIS
Frame High strength steel tubular frame
Front suspension 41 mm hydraulic telescopic USD fork, with adjustable spring preload and hydraulic rebound
Front wheel travel 170 mm
Rear suspension Double-sided swingarm in box-type aluminum with a single shock on the right side, with adjustable spring preload and hydraulic rebound
Rear wheel travel 170 mm
Front brake Double 320 mm stainless steel floating discs, Brembo radial-mounted calipers with 4 opposed pistons
Rear brake Ø 260 mm stainless steel disc, floating caliper with 2 pistons
Wheels Spoked
Front wheel rim 2.50” x 19”
Rear wheel rim 4.25” x 17”
Front tire With air chamber 110/80 – R19”
Rear tire With air chamber 150/70 – R17”
ELECTRICAL SYSTEM
A/C generator 430 W
System voltage 12 V
Battery 12V – 12 Ah
All photo credit: Moto Guzzi
