SW-MOTECH has revealed a new lineup of waterproof motorcycle bags at EICMA.  The company says there is a “…suitable SysBag WP for every application and every motorcycle.”
Depending on your requirements, the new Sysbag WP lineup consists of small, medium, and large bags.  Each of the models varies in luggage volume and type of attachment.  But all of the bags have a roll-top closure and an overlapping lid.  There’s also a removable inner pocket and two “freely positionable” dividers with velcro fasteners to facilitate separating your luggage.
SysBag WP bags
Each of the SysBag WP L side bags feature:
  • Roll-top closure
  • MOLLE patch for attachment of additional pockets
  • Reinforced carrying handles
  • Reflective details for better visibility
  • Lashing eyes for the attachment of cable locks
  • Velcro fasteners for fixing the excess belt lengths
SysBag WP L bag
The SysBag L side bag is the largest SysBag model.  SW-MOTECH says it has been designed for off-road use.  The bag’s front strap buckles are placed on the upper side to ensure that branches etc., cannot get caught while riding on narrow trails.
The outer edges of the bag are covered with “Hypalon,” which is claimed to provide extra protection in the case of falls.  Finally, four compression straps on both sides allow the bag to be “lashed down into a compact unit, even with a low load.”
SysBag WP L bag
The SysBag WP L bag.
SysBag L side bag specifications:
Material
  • Made of TPU material
  • Roll-Top made of 210 Ripstop TPU
Function
  • Fastening to the PRO side carrier or by looping on the rear or third-party carriers
  • 100% waterproof in the main compartment
  • One waterproof zipper compartment each on the inside of the lid and the additional compartment
  • Four plastic feet for improved stability and protection of the underside
  • Volume: 22 – 40 liters
  • Dimensions: 48 x 22 x 41 cm  (18.9 X 8.7 X 16.1 inches)
  • Weight: 2.9 kg (6.4 pounds) -without adapter plate
  • MSRP €220 ($~245)
Sysbag WP M side bag
The next size down bag is the SysBag WP M side bag.  SW-MOTECH says that it is a “robust soft luggage solution with an adventure look.”  It mounts to SW-MOTECH’s SLC carrier or by “looping it on the rear.”
According to SW-MOTECH, the SysBag WP M is similar to the company’s waterproof tank bags.  Both have a TPU base and EVA parts.  These two materials are Thermo welded and joined together to form a compact waterproof bag.
SysBag WP M
The SysBag M side bag.
SysBag WP M bag specifications:
Material
  • Made of TPU material and EVA plastic
Function
  • Fastening to the SLC carrier or by looping on the rear or third-party carriers
  • 100% waterproof
  • Waterproof zipper compartment on the inside of the lid
  • Two adjustable positions for mounting on the adapter plate (50mm difference)
  • Volume: 17- 23 liters
  • Dimensions: 32.5 x 16.5 x 41 cm  (12.8 X 6.5 X 16.1 inches)
  • Weight: 1.9 kg (4.1 pounds)  -without adapter plate
  • MSRP: €170 (~$190)
SysBag WP S side bag
The smallest of the new SW-MOTECH SysBag side bags is the SysBag WP S.  It fits both enduro and road category bikes.  The bag has an integrated EVA inlay to provide shape and stability, while the bag’s lamination makes the bag waterproof and UV-resistant.
Sysbag WP S side bag
The SysBag WP S side bag.
SysBag WP S specifications
Material
Function
  • Fastens to the SLC carrier or by looping on the rear or third-party carriers
  • 100% waterproof
  • Volume: 12- 16 liters
  • Dimensions: 32.5 x 16.5 x 33 cm  (12.8 X 6.5 X 13 inches)
  • Weight: 1.6 kg (3.5 pounds) -without adapter plate
  • MSRP: €140 (~$157)
PRO Cross WP and PRO City WP tank bags
Last up are the PRO Cross WP and PRO City WP tank bags.  The PRO Cross WP is the small strap version, while the Pro City is designed for the PRO tank ring.  According to SW-MOTECH, the body of the bags are made of TPU material.  There are no seams, holes, or exposed zippers.  There’s also an EVA lid that has a magnetic closure to make getting to your gear easier.  SW-MOTECH says the  new tank bags provide “a completely waterproof sanctuary for all belongings that are much better off in the dry.”
PRO Cross WP strap tank bag
Using straps, the PRO Cross WP tank bag is under constant tension and has a tight fit.  SW-MOTECH says that even on small enduro bikes with a narrow tank, the PRO Cross WP will fit.  The bag can also be quickly removed using the four quick-release fasteners.  And when it comes time to refuel, only the front two buckles need to be undone.
The Pro Cross WP tank bag with strap connection.
PRO Cross WP strap tank bag specifications
  • Top of the tank bag made of laminated and dimensionally stable EVA material
  • The overlapping lid prevents water penetration
  • Magnetic securing of the lid
  • Welded body made of TPU material without seams
  • MOLLE attachment made of sturdy Hypalon material
  • Sealed zippers
  • Volume: 5.5 liters
  • Dimensions: 24.9 x 20.7 x 19.9 cm (9.8 X 8.2 X 7.8 inches)
  • Weight: 0.9 kg (2 pounds)
  • MSRP: €130 (~$145)
The PRO City WP is for touring enduros that have a sloping tank.  It offers a waterproof 9-liter storage compartment for your gear.  As a result of the bag’s design, there’s no need for a rain cover or an additional inner pocket.
Inside the bag is an adjustable partition with an additional mesh compartment that provides storage options.  The bag’s two outer pockets have waterproof zippers and are also waterproof.
PRO City WP tank bag with ring connection.
PRO City WP tank bag (tank ring mount) specifications:
  • Top and bottom of the tank bag made of laminated and dimensionally stable EVA material
  • Welded body made of TPU plastic without seams
  • Viewing compartment for smartphone or cards in the inside cover
  • Sealed zippers
  • For PRO tank ring
  • Volume: 9 liters
  • Dimensions: 35.7 x 32.1 x 20.6 cm (14 X 12.6 X 8.1 inches)
  • Weight: 1.4 kg (3 pounds)
  • MSRP: €220 (~$245)
You can find streaming videos for SW-MOTECH’s new 2022 gear on their streaming website.
